too much oil in motor
My buddy overfilled his oil a few times and ran at the strip, did some road pulls, etc and nothing happened. I wouldn't recommend overfilling oil, but I wouldn't have a nervous breakdown over it either.
I accidentally added a quart too much, but my **** self checks the oil level 4x before starting, so I caught it.
Since I have a fumoto valve, I just jacked it back up, drained out a quart, and problem solved.
http://www.quickoildrainvalve.com/
I've had the fumoto for a year - I love tool-less, no-mess oil changes.
I believe that if you track the car it would be better to be a little over then a little low. You dont want to be half a quart low when oil is sloshing and you're making a hard right into a corner.
I always make sure my oil level is at the high mark when going to the track. When I'm not at the track I just leave it between low and high.
Well now im all paranoid. I changed my oil and filter about 1000 miles ago and just dumped a full 5 qt jug of MB1 into it. On the dipstick the oil level reads like 1/8 of an inch above the high/full notch on the stick. I read that these engines use a little bit so i didnt even give it a second thought when i looked at it. My engine hasnt used so much as even a drop in the last 1000 miles so it still reads like 1/8 of an inch above the high notch.
