too much oil in motor
#36
I buy 6 qts and i drain the motor and let it sit for 10 min then put 2 qts in and turn the motor over...Not start.Then i take the filter off and let it all drain for 10 min and then i put the plug on and new filter and fill her up i use a little less then 5 qts and that puts it right in the mid of both notches on the dip stick at then end of the day.
Just put in 4qts then let it sit then just add little at a time until it get up on the dip stick. after a day on the new oil check back on the dip stick for the next 2 or 3 days to make sure your motor didn't suck any in. Or if you have to much!
I change mine at 3000 miles and that is about a month or 2 months of driving for me.
I find the Flush Helps a lot! Pulls a lot of the trapped oil out of the small parts.
#37
im a lil over the second line on the dipstick ( like 3 millimeters or so) no too much....i think i should be okay....RIGHT guys ? :-P
And also i just put 5W-30 cuz its kinda cold here these days in the mornin....but usually i use 10W-30 thru the summers. im in freakin Houston, Texas BTW. Just moved down from cali. dont really like the weather here. sucks
MRfabolous
48
Aug 17, 2017 07:15 PM
[WTB] looking for evo oil pan
GravityKnight
May 12, 2015 10:54 AM
kyoo
13
Oct 27, 2014 12:24 PM
stealth-wrx
10
Jul 2, 2006 08:47 PM
