Who's manifold is this T3/t4
#61
You guys that buy this manifold are retards!!! IT WILL CRACK and you will get it re-welded and it will crack again and again.. While your at it why dont you buy a KNock/off Ebay wastegate, bov, fmic,turbo
I would say that a Top Mount takes about 10-13 man hours to build am I close geoff?
This is about a peice of metal that routes air, if its junk then its junk, no big deal, was only 130 bucks......... i laugh at that.
#63
Robots build Full-Race's manifolds
Scorke
#66
Geoff, yes its true the collector looks terrible, if Im not able to fix it I will not use it.
The dragster has RAS , springs, and tit retainers, also z32 maf and jim wolf ecu with big injectors, so is only stock pistons , rods, and head, also has an ebay intake manifold. Im building a second car with better parts on the motor and a bigger turbo.
Also , to the guy that says his friend welded the manifold I can say yours is a fake too, is exactly as mine, even the straingt tubes have a different color as if they were sanded and the outside welds have the same defects. Maybe your friend took off the emblem and did a little finishing but is a fake. If you paid more than $200 for those headers , you were scammed,
a picture of my ebay headers beside your picture will show you.
are you really serious ? look at your welds compared to mine.... mine look nothing like yours. Pipe color really is not important as if i took a pic now, it looks nothing like after even running for 20 minutes. But i can guarantee you, my welds dont look anything like yours... they are damn near as clean as the full race mani.
at least if you are going to compare a mani to yours, and want to compare looks, make it reasonably close. If i wanted to take the *** pain of a time to take my setup off to show you my collector, you'd notice an even bigger difference as my pieces all come together in a very clean and defined point.
#67
this turbo kit looks nice for the evo8
http://www.xs-power.com/turbos/turbo005.html
#68
#70
The problem with the manifold is that first off the didnt purge the inside of the collector,which if they didnt purge the collector,im pretty sure they didnt purge the runners either..So all the sugaring the you can see in the collectors is most deffiantely in the runners also..Which can come off and end up in your expensive turbo,cause crappy flow due to the obstructions,cracking,etc..A manifold that is purged and welded correctly,while more expensive upfront..Will end up up paying for itself later if it destroys your turbo,or worse your engine..Me being a welder can see people buying knock-off intakes,exhausts,etc..But do your self a favor..Dont buy cheap stuff thats important..Like internals,wastegates,manifolds,throttlebodies..You are only screwing yourself..Just some food for thought..Justin
kaonashi
ExtremeTurboSystems.com – WA
32
Feb 26, 2008 12:21 PM
