Unreal Dyno Results...
it jumps slowly. at wat mileage does the stock clutch usually wear out at? i only hav 7900 miles... btw, isnt jestr one of the ams tuners? or izit jensen? yea i'll take it to the dealer wen i get the chance n c if they can do sum diagnostics n put bak the stock map. they do hav stock evo maps rite?
wow are you totaly new to evos? 420... i love green too but fix the problem before tokin and not being able to think clearly lol.
If your hitting full boost most likely its not a leak or turbo issue. Is your boost fluctuating? or is it inconsistant, whats your timing at? there is no "set mileage" for the clutch to wear out, if you suck at driving or see the track a lot or love launching either tcase or clutch is gonna wear out.
did you install the mods? i mean we need more info... more history
naw it doesn't fluctuate. i've done sum 6k launches b4, but not much. all these mods hav been installed within a year and 3 months, didn't buy everything at once and install em at the same time. well i'm new to the technical problem diagnosting stuff n thats about it. some ppl say i should datalog it and check if it's knocking real bad and check the a/f sensor or flash my ecu back to stock n c how it runs, maybe the timing is off or somethin. i think ill just take it to the dealer n hav them datalog it since my evo buddies r busy now days.... before my car was running cherry, even w/all the mods. n all of a sudden the problem jus came up
welp, i called mitsu dealer today n asked if they do datalogging n they said only for stock cars, not modified ones >.< sh*t i'm stuck now n i gotta c if any local evo owners where i live- oahu hawaii kno how to datalog n find problems. but the boost solenoid not actuating the boost properly or knocking bad sounds real possible.... cant be the ecu flash cuz wen it was flashed i felt more hp gain and the problem didnt occur til later.. i'm sure there's expert tuners here, but most of u r in the mainland :-/
dude sell your car, I am not the person to be a dick on here, but DAyHAM MANG. you dont want the dealership to datalog jack ****. Jestr is his own self he tunes cars for himself not ams. What gauges do you have in your car? and if your clutch is slipping thats going to cause some issues there too. Should have bought a MBC instead of that electric junk
rEvolution420 check out www.mellontuning.com I have a list of equipment you need to log the car and I can help you interpret the logs. I even have a video tutorial.
you should get a boost leak test. Then check if you wired your EBC correctly. I heard a lot of really bad things about dynoflash so I would recommend you get flash back to stock then getting a custom flash from someone else
yea it sputters and lags above 2.5k rpm. the mph n rpm meter goes up slowly.. it's suppose to have the smooth tone when you gas over 4k rpm and it should pull, but mine doesnt.
