Tre Rear Differential Upgrade Service
#226
Okay, I re-read the whole post & am ready to pull the trigger on this upgrade. My car pushes wide powering during mid & exit--especially on later runs when the tires are getting too hot.
My car's turn-in is very good, relatively speaking.
Not sure if 1 or 1.5 is what I need. The car is incredibly stable in heavy transitions & my style is very aggressive--and I don't want to lose that stability--or I may crash Sounds like they both act the same under power, but the 1.5 will start the rotation when/if the throttle is dropped.
I had 2 STis & always left the diff in auto--I liked the slight rear bias when powering out, as it rotated nicely & predictably while I rang it's neck.
What ratio have you cone guys gone with & are you happy w/ the car now?
Thx,
George B.
Thx,
George B.
#230
George B.
George B.
I spoke with Jon @ TRE about this, what your trying to cure (pushing wide mid to exit) is exactly what is reduced with his diff, sometimes a little correction will be required on exit . Also what I gather from our conversation is that the 1.5 holds the "lock" on deceleration (1 way does not), but not as aggressive as the 2.0 (which would be like what a drifter would need).
For autox he recommended the 1 way, which may help to keep the stability.
Hope that helps
Duncan
PS I thought loose was fast
#231
Not tight & super-stable is even faster (for me)
Thx for the info Duncan. I'd be comfortable w/ the1.5s help in turn-entry rotation, but my car seems to leave everything thing else in the dust in the slaloms & offsets because I literally drive it past the limits--and somehow don't spin... I just don't want to give that rock-solid stability up.
If I tried this level of attack in my old C5 Z06 Vette (which was a bada$$ ASP car), I'd have spun immediately.
#232
This vid shows exactly what the issue is & where this mod should help (180s & sweepers--I had to be waaay too patient)...
The course was not friendly to my car (all the 180s & no transitions), and you can hear me chopping viciously @ the pedal in the final right sweeper, as the car wanted to push wide.
My A6s are almost shot, but this was my 1st local loss (P2 by .2xx in a class of 9) in a long time...
http://www.youtube.com/watch?v=a0oZr5pHOts
I'm dropping the car off today to get this TRE mod started...
#235
a vid of car with TRE rear diff in it... the advanced observer should be able to see how the car drifts with slight oversteer out of most turns.
http://www.youtube.com/watch?v=wFvC6dSf2Fw
you can kinda see the car from this video.. hard to see, but car is neutral sliding alot.
http://www.youtube.com/watch?v=KVf2-xkRxYU
ofcourse the badass KW robsipec race shocks helped too
#237
