Tre Rear Differential Upgrade Service
#316
What fluid is everyone using?
When I first put the diff in I was using redline 75w90ns(no friction modifier, Jon recommended). It made tons of springy clunky noises every time i made tight turns. I called Jon and he said it was supposed to do that and if it locked up too much to add a little fiction modifier. I ended up draining it out and using the regular Redline 75w90(stuff w/ friction modifier) because I thought it was locking up too much and that it would be too loose for me on track.
I have taken the car on track and now I feel like I might want the car a little looser. Should I throw the fluid without the friction modifier back in or try something different like the oem diaqueen?
#317
I have never tracked my car, or abused it, so I think it's normal per my conversation w/ Jon.
#318
^^Not OCD? Man you're the reason Obsessive Compulsive Disorder is in the DSM-IV :P. BTW, hit me up .
ps. this rear diff really makes your rear end swing, I've felt first hand in Bill's (revvin9k) car.
#319
I personally am using AMSOIL in my TRE rear diff. I have changed it out so often, it's well, borderline OCD. Fluid is always super clean. In 3k miles I have changed it 4 times.
#322
Has anyone tried to get this mod recently?
I send mine in to Jon nearly two months ago now and have heard absolutely nothing for the past month... I know his website says he would be gone till beginning of July but im starting to get antsy now.
If anyone has gotten theirs recently I would very much appreciate a PM.
Thanks,
-heeltoer
Thanks,
-heeltoer
#323
Diff+ Rear swaybar question
What seems to be the general concensus regarding the rear swaybar with the TRE diff for road racing applications?
I'm just about the install this, and currently have a honking rear 27mm bar
Spring rates on my the coilovers are 10K, so would a stock bar be sufficient or maybe a 24mm adjustable?
Thanks
Thanks
#324
Thanks
Thanks
Not sure if this will help you much since I do not track my car but....
I am running the Perrin sway bar with the Perrin mounts and I have it set on the middle setting.
While I was able to get the rear end out with just the diff, it seems more controlled with the rear sway, that is if you don't lift.
My ignorant .02
#325
Thanks,
-heeltoer
Thanks,
-heeltoer
#326
Thanks
Thanks
EVOlutionary
#327
I've never driven Mid-Ohio (only watched races there) but it looks like to be filled with mid to high speed corner. Was the car neutral at that setting on all corners? Was it any different on a slower speed corner like the keyhole? or a transitional (late apex?) corner like 13 / carousel?
Thanks for the feedback. Jon responded to my emails today.
-heeltoer
-heeltoer
Use the rear bar to balance the car. With that low of spring rate on a racing application I will guess you will probably want the big bar. Just got back from Mid Ohio and I was running very high rear rates and a bar set on full stiff and the TRE rear diff and the GruppeS reflashed ACD controller and a big rear wing and it felt very neutral on mid corner with just a hint of rotation upon on-power corner exit. . .
EVOlutionary
EVOlutionary
#328
Thanks
Thanks
Anyway, I have now finally got the car neutral again, after increasing the spring rates in the front and setting the 25mm bar to its softest setting (170% of stock) and increasing the rear camber to -2.25. I'm at 14K/16K spring rates F/R by the way. I'm thinking of going back to the stock rear bar, because I'm still getting rear wheel lift until corner exit, and it may be limiting how soon I can go to full throttle.
Mike
#329
I have the TRE rear diff and the 27mm rear bar, I am not sure what my spring rate is (I have RobiSpec K&W clubsport) with the stock rear spoiler and I love it. The car is great in low and mid speed corners. I have not had a chance to try high speed corners.
Hope this helps
Hope this helps
#330
EVOlutionary
EVOlutionary
