my dyno sheet
Old Dec 18, 2007 | 04:28 PM
ethan169's Avatar
holy leanness batman, i feel like those numbers are higher for those mods untuned?
no?
i only got 280awhp with tbe and intake 295tq
Old Dec 18, 2007 | 06:45 PM
Redline-Z's Avatar
Veteran: Air Force
no?
If you have HFC subtract about .8 from your tailpipe sniffer, even then you are way lean. Also, the downward jumps you are seeing are possibly from knock over 5 counts and it will get worse! Get that thing tuned or get an email flash from a good vendor on here for minimal money. Also DL Evoscan or Mitsulogger and log that thing STAT! You are not even close to the right track and need to get your car fixed ASAP.
Old Dec 18, 2007 | 07:04 PM
EvoJoeIX's Avatar
no?
his car obviously isnt untuned if hes in the 14 area WOT....
my car is untuned and my AFR is below 10.0 at WOT and it wont even register on my AEM wideband
Old Dec 18, 2007 | 07:12 PM
Redline-Z's Avatar
Veteran: Air Force
Pig rich is the way they come! To the people that say don't install an intake you'll run lean, are Idiots! Add a fuel pump and watch that number drop even more
Old Dec 18, 2007 | 08:15 PM
rcheung's Avatar
So your saying running an intake will not make you run leaner? Are we talking about a cone style intake and not just the filter replacement?
Old Dec 19, 2007 | 09:26 AM
9sec9's Avatar
AFR's don't even appear to be correct for the track of the hp/tq. Notice how the AFR finally gets to 14 area and hp/tq do not respond to the 'improvement'. Much more than AFR is the problem.
Old Dec 19, 2007 | 09:35 AM
TeStUdO's Avatar
Thanks for being so ignorant. If you install a conical filter, it will very likely throw off your MAF readings. That in turn, will make your ECU think there is a different load on the engine and use a different part of your fuel map. That, plus the agressive timing the stock ECU has, will make you run lean.
GTaker
15
Aug 19, 2011 10:00 PM
turbozee
Aug 27, 2007 02:43 PM
Thugline
19
Jun 16, 2007 02:52 PM
RedEvolution8
Oct 30, 2005 11:07 AM
Alfriedesq
Apr 18, 2003 04:05 AM
Quick Reply: my dyno sheet
