Slave cyl pushrod stuck aka piston in slave
Old Dec 18, 2007 | 06:16 PM
joosdawg's Avatar
So i was having disengagment problems and a stiff strange feeling pedal so i took the slave off the tranny to inspect the TOB's engagment in the pressure plate. Well i went to put the slave back on and the rod is stuck out, i cant push it in for $hit and its impossable to do so. I even took the boot and pushrod out and tried pushing it back in with a screwdriver as hard as i could and still nothing! Is the problem the slave siezing on me or is there more to the story that i may not be checking? note last time i pushed the clutch in it felt wierd coming back up and was kinda jerky.
-Ryan
Old Dec 18, 2007 | 06:35 PM
Nad1370's Avatar
No way you'll be able to push it back in manually if there's fluid behind it.
Crack the bleeder screw so fluid would leak out then push it in and bleed it.
I personally would take the slave cyl out, take it apart and inspect it. Just be carefull not to tear any seals or O-rings.
Old Dec 18, 2007 | 06:40 PM
joosdawg's Avatar
Every time i dropped the trans i was able to just insert the rod into the fork and push it closed and bolt it up. Why would it not work that way this time?
Old Dec 18, 2007 | 08:58 PM
94AWDcoupe's Avatar
when are you going to answer my PM?
when you cant push the slave back in, that means your clutch rod is over adjusted. fluid cant return to the master. its like your foot is on the pedal all the time.
jimbo74
Lancer Tranny/Drivetrain Tech
28
Aug 28, 2016 08:47 PM
iidrakeii
Nov 12, 2011 07:24 PM
KlanjacOFF
10
May 29, 2011 05:19 PM
JRR
Jul 14, 2010 09:31 PM
nhsean69
Mar 11, 2010 07:26 AM
Quick Reply: Slave cyl pushrod stuck aka piston in slave
