Do I have a warped flywheel?
So this last Sunday I was beating the EVO pretty hard, lots of launches and some AWD drifting. (finishing off the stock advantages) On the way home the car drove normal. Then on Monday when I went to work the clutch was acting up on me. This is how it is acting:
Clutch enguagement is pretty high on the pedal, it has always been this way and that is what I am used to. However when in First gear and starting from a stop the clutch dose a skip, it's not slipping it just seems like is studders once and then enguages.
At first I just thought I needed to adjust the pedal.
I adjusted the clutch pedal all the way down, and up and it dose the same thing. I checked all the bolts, the slave cylinder, linkage, and found nothing out of the ordinary.
The clutch is not slipping! Just crappy engagement in first, It starts to enguage fine execpt at the very end, it feels like it is dumping it at the very end. All other gears are fine. After all the adjustments and no changes, I decided to give it a launch and it did great, no problems. It only happens at a slow start in first.
So after some searching and thinking, I am guessing I warpped my flywheel.
The car has an aftermarket ACT clutch and a reserfaced stock flywheel. It has work perfect with quite a few launches and lots of hard driving (SCCA) for 10,000 miles.
Let me know if you agree, or have any different ideas. Thanks!
But it is possible you overheated your flywheel and warped it, espcially since you had it resurfaced once already which would increase the chance to overheat it.
that's not ur flywheel bro... that's a program in your ecu called your PROM. when you ride your car hard for a day it recognizes and remembers how your driving and engaging your clutch so when you try to drive normal after its not used to you driving like a granny so its sluggish and hard shifts.. it got used to your race style driving that's why it engages perfectly when you launch. if you were to drive it normal for a day and deal with the hard shifting it will adjust back to normal driving conditions and not act up.
Thats funny. I wish a car could do this. But not true.
as that disc wears...the pedal will get closer and closer to the top.
It's possible to warp the disc which is a sprung hub. The ACT's are.
Flywheel will have some bluing and high spots caused by the heat from launching.
This is where it's better to get a carbon style clutch for life against repeated hard launches.
