boosting 12psi HELP!!!!
I'm sure somebody can better explain but it looks like you're running at waste gate pressure. Have you installed an aftermarket boost controller? Where did you "T" into for the Gauge, was it by the fuel pressure regulator?
looks like you bought a used evo and the original owner had a manual boost controller. before trading it in he/she removed the boost controller, and instead of replacing the stock vaccum lines, which have small brass pills in them, used normal vacuum lines. youll have to either get a mbc, ebc, or order the stock vaccum lines.
