Those who have boost guages that read in "BAR"
Old Aug 22, 2003, 07:02 PM
  #31
Crufty Dusty's Avatar
How's it going? What color is your E8?
Anyway, here are my numbers, using Defi BF:
3rd and 4th gear: 1.2 bar held
5th and 6th gear: 1.3 bar held
Peak boost 1.4 bar, 1.5 bar with full load and A/C on.
Operating conditions:
Full tank of gas (Shell V-Power)
Temperature: 28 degrees C
Dew point: 24 degress C
Relative Humidity: 78%
Pressure: 29.83 in. Hg
Car is totally stock.
Originally posted by GDB
I don't think this is weird. Your description is very informative: peak boost varies according to gears. Higher load on the engine means you'll see higher peak boost, given all other things equal.
I'm still breaking in mine so I can't really vouch the numbers you just described, but have a friend who observed exactly the same numbers as yours.
BTW would be very informative for everyone to disclose:
Gear
Boost peak
Boost held
Peaking at 1.5bar tapering to 0.9bar at redline is VERY different from holding 1.5bar all the way to redline.
Also, IMHO the variations *could* partly be due to the MEASURING device. For e.g. I have heard numerous posts that say Defi boost gauges are over-optimistic on the boost readings. That is, a 1.5bar displayed on the Defi could be registered 1.35bar on a Blitz EBC digital read-out, or a diagnostics device (SECS).
Which number do you take? Personally I'd lean more towards readings off a diagnostics device, so numbers in Defi is a bit off.
All of above IMHO. Open for discussion but please don't flame
Old Aug 23, 2003, 09:09 PM
  #32
Sunder's Avatar
Remembering that I drive an Evo 6, I hit 1.1 bar modified, but only ever so briefly. If I plant my foot in 1st/2nd/3rd, I'm redlining before I even get a chance to look at the boost guage!
If I plant my foot from say 40mph in 5th, then it slowly builds up to about 1.1-1.2 bar.
Old Aug 25, 2003, 05:39 AM
  #33
Eric Lyublinsky's Avatar
1.3 1st 2nd 3rd
1.33 4th and 5th
Greddy gauge 1.3= 18.486
1.33= 18.912
Now getting cool this morning 1.36
Old Aug 25, 2003, 05:57 AM
  #34
boostedwrx's Avatar
the stock ebc sucks ***, its too spiky. Mine will spike up to like 1.4 and then back down to 1.3 all the time it seems. Ghey... still havent hooked up the darn sbcid
Old Aug 29, 2003, 08:36 AM
  #35
Adolfo Rapaport's Avatar
My stock was 1.35 bars tappering to 1.25. I just installed the Exede with boost control, turboback exhaust and I am peaking at 1.45 bar and tappering to 1.4 to redline. I'm also only running the 91 octane map. The difference from stock is amassing.
Old Sep 1, 2003, 05:06 PM
  #36
bpclements's Avatar
I was hitting 1.32 stock and tappering down to 1.2.
Old Sep 1, 2003, 06:24 PM
  #37
Changy's Avatar
Out of the box.
Attached Thumbnails Those who have boost guages that read in "BAR"-lg_cimg0214.jpg
Old Oct 18, 2003, 01:12 PM
  #38
90GSX-03EVO's Avatar
Lucky Bastard.
I wish we got the 6 speed tranny.
Old Oct 18, 2003, 01:22 PM
  #39
Hooptie157's Avatar
1.4 1st
1.5 2nd
1.6 3rd, 4th, 5th
Held strong with Greddy profec spec B-II
Old Oct 18, 2003, 01:34 PM
  #40
dEdiYT11's Avatar
With my Profec E-01 and FCD, in 3rd 1.7bar (24.99psi) held, with NX-intercooler spray sometimes 1.8bar (26.46psi) held in 3rd or 4th gear
Old Oct 18, 2003, 04:03 PM
  #41
Hooptie157's Avatar
whoah 26psi!!! I hope your not using the stock fuel system and injecetors for this cause you'll be running really lean.
Old Oct 18, 2003, 04:31 PM
  #42
I wonder how much timing is being pulled at that much boost. I hope that nobody in here ever runs over 24 psi on the stock fuel system.
Perhaps your setup has some degree of inacuracy?
Old Nov 25, 2003, 02:45 PM
  #43
EVO_RPM's Avatar
1st: 1.38
2nd: 1.3.38
3rd: 1.4
4th: 1.43
5th: 1.4
Whats everyones vacuum reading at idle?
Edit: just ran it again.. new readings
Old Nov 25, 2003, 02:57 PM
  #44
evil8's Avatar
You're getting more boost at lower gears that is strange, usually it's the other way around, is your car stock?
To answer your question I'm getting -.62 vacuum at idle once the car is warmed up. Anyone else want to chime in with their idle vaccuum on their Blitz DTT? I think mine is a bit high.
Old Nov 25, 2003, 04:17 PM
  #45
Sweft's Avatar
Originally posted by ericomundo
Actually 1 bar = 14.503 ... hey, that 0.005 makes all the difference
btw, here's a nice site for conversions:
http://www.cis-online.co.za/tables/pconvsgtab.htm
If you're getting **** on the guy let me get **** on you.
Rounding off to 5 significant digits 1 bar is equal to 14.504 PSI. To 9 significant digits it's equal to 14.5037738.
Quick Reply: Those who have boost guages that read in "BAR"
