Compression Help?
Old Dec 20, 2007 | 05:48 PM
roberttonge's Avatar
Compression Help?
My car all of a sudden (JDM EVO VII) is not idling properly. The car also loses power up top. Did check and my manifold was cracked, this was fixed but I have the same problem.
The mechanic did a compression test:
1 & 2 reads 150psi
3 reads 125 psi
4 reads 175 psi.
What should the psi be?
what do you think is wrong?
He assumes valve problem, retainner spring, or piston.
Need help fast all the way in the Caribbean.
email me too robert.tonge@cwdom.dm
Old Dec 20, 2007 | 05:50 PM
E VOL IX's Avatar
what does your oil look and smell like??
if it is really thin and milky you have a bad head gasket...
does it soudn like a subaru?? if so u have a bent valve
they should read anywhere from 150-175 or so
Old Dec 21, 2007 | 05:15 PM
Thanks for the help and also reading old posts.
The compression test was done wrong so I got the right method off the site.
The problem was the plugs.
