how much hp is the walbro fuel pump good for
unfortunately as Mellon found out recently a walbro is at it's limits with a 35r
he had to add a kenne bell boost a pump in order to maintain enough voltage to feed the beast
in my opinion a 35r is where you drawn the line to needing a double pumper or something off the likes
mellon ftw
1 Post
on my stealth I have a fuel pressure transducer and can log fuel pressure vs boost to make sure it's rising 1:1 from 25-35psi it's very handy for finding fuel pressure issues. Do you have anything like that with your setup by chance?
with pump gas I'm at 11.5:1 AFR maybe you're in the 12.5:1 area saving some fuel and running some massive injectors. Are you in any meth/alky which would lessen the need for gasoline? just trying to understand your scenario because that's pretty interesting.
Sorry thats on race gas (c-16) Shouldn't be that big of a difference though. Have you taken off your fuel rail yet? Just wondering If you have seen the size of the inlet in it?
-Em
with an AMS 35r in the dyno i forgot to activate the sec. pump and with only one walbro it make 553hp at 32 psi with 93/meth. for insurance im activating now the sec. pump at 28 psi.this is my own dual setup.sec.pump activated by the Electromotive engine management.
The walbro 255HP will start to have flow issues around 500-540 whp.
No one NEEDS a regulator if your not running dual pumps at the same time. regulator is still nice to have but isnt needed.
DevilDog7
May 31, 2012 06:44 PM
JDM EVO PANAMA
22
Oct 18, 2010 05:15 AM
alktrio06
Dec 6, 2009 12:00 PM
hytek369
10
Sep 10, 2008 04:22 PM
