NEED HELP! Is my ACD broken?
Old Dec 24, 2007, 08:51 PM
MattevoVIII's Avatar
i didnt get the code yet? hmm that makes sense
on wed im going to devo il get the car checked up
check the pump
check acd
check abs wheel speed sensors
Old Dec 24, 2007, 08:55 PM
Abs sensor is not....engine check turned on thou...wasnt exhasut related i bet
Old Dec 24, 2007, 08:57 PM
i have a feeling its Acd transfer case
either
-little fluid
-bad pump
since when the car turns its using the acd more and thats where it goes worng and seems like it locks up
that would make sense
Old Dec 24, 2007, 09:02 PM
eag36's Avatar
Originally Posted by KcEvil8
but if the ABS sensor is bad..it'll kick on the ABS light on the dash
hmmm... true.
I really don't think it's the pump though. Lets say the ACD was going into lock-up causing the issues while steering... the ACD only locks up when the pump is on. So if the turning issues are from the ACD then it's a bad sensor of sorts.
The other thing i'm thinking for the turning issue is a bad front diff that is locking up when he takes sharp left turns, but that doesn't explain the ACD malfunction unless the computer knows the front diff is messed up and turns the ACD off to save it.
I guess we'll find out on Wednesday.
Post up what it is, don't leave us guessing.
Old Dec 24, 2007, 09:05 PM
eag36's Avatar
I think you are mistaken on how the ACD works. The ACD only engages when it senses slip on wheels, and only locks up the center differential. this has nothing to do with turning unless you are accelerating while turning enough to slip / slide which you shouldn't be doing if your car is having these issues.
Under normal driving where the tires are not slipping the ACD is not doing anything.
Old Dec 24, 2007, 09:18 PM
yeah i have no clue rite now
ill post it up on wed
ill know for sure
i hope it's notihng bad
Old Dec 25, 2007, 02:31 AM
SpeeDeviL's Avatar
I have the same problem
some times when i start the car the 3 light gose on, I wait for the car to warm up than I turn it off than start it again, and it's back to normal, only one light in on Tarmac.
Dose that have to do with the pump? or something eles??
Old Dec 25, 2007, 12:02 PM
i have no clue yet i checked i have all my fluid....so idk either it doesnt... the pump dosent work...
or someitnhg else is messed up..
Old Dec 25, 2007, 01:26 PM
Adrenaline718's Avatar
You may have messed up your mass airflow sensor. Did you recently do anything with the air intake system? Turns out the ACD, Evap Emissions and Barometric Sensors are all on the same circuit as the mass air sensor, and if one goes out the ECU will throw all of the codes. When the Service Engine Soon light goes on, all three of the ACD lights are on.
I just had a problem like this recently, and the tech at the dealer figured it out after much tinkering and testing. New MAS on order, and problem is solved. Just another thought. This wouldn't explain the strange turning, but the erratic idle could definitely have something to do with the MAS.
Old Dec 28, 2007, 11:50 PM
Davethewave's Avatar
Ssdd
same thing here bro, happened after i replaced my clutch.
Originally Posted by Adrenaline718
Turns out the ACD, Evap Emissions and Barometric Sensors are all on the same circuit as the mass air sensor, and if one goes out the ECU will throw all of the codes.??
that is retarded, why the h*ll would MMC do that.
i think this is what is going on in my car because i was still able to take a corner at high speed and keep traction without, other than having 3 annoying lights on my ACD sometimes, the car drives fine.
Old Dec 29, 2007, 12:08 AM
housedj's Avatar
have u checked the CV boot on ur driver's side axle? since the trans faces that way, it might be spinning too fast causing the front LSD to lock late, but i would check the other stuff mentioned above as well.
diff fluid check
ABS sensor
scan tool for the code
driver's side wheel bearing
drivers side CV boot
driver's side axle (in case it might be coming out)!
Old Dec 29, 2007, 04:24 AM
akemi27's Avatar
why are evo owners so cheap? just go to your local evo specialists (stealership) and have them figure it out...if the job costs too much take it somewhere else! at least you'll know what the prob is to get fixed! quit ranting and fix it already
Old Dec 29, 2007, 06:21 AM
Davethewave,
You really should have the dealer check your MAS. If you car ever runs erratic it could definitely be that. I had mine replaced finally yesterday, and it runs smooth again, and all lights are normal again.
If you are getting a check engine light along with the three ACD lights, go to Autozone and have them tell you the codes. If it says something like "Barometric Pressure Sensor - Circuit Low" then it very well may be the mass air sensor malfunctioning and causing codes to show up along that circuit. Mine showed three codes: Barometric Pressure Sensor, Evaporative Emissions Sensor and Throttle Position Sensor.
The reason I knew it was something else was that the car was driving pretty totally normal (except for erratic idle at times) but was throwing a throttle position sensor code - it didn't make any sense. The tech at the dealer confirmed it was the mass air sensor and ordered a new on under warranty. Problem solved and the car runs terrific now!
Old Jan 17, 2008, 08:42 PM
boostin06ggevo's Avatar
so update on us on the info what what was the problem????
Old Feb 10, 2008, 12:00 PM
i forgot to tell you guys what happened everyoen wondered
so after my engine was built 2 silly things were forgoten
notihng big
imagine engine harnesses
2 clips were missing thats it
and thats y the car behaved like that
it was 1 minute fix its all good now
dont forget the clips ppl
Quick Reply: NEED HELP! Is my ACD broken?
