downpipe question...
Hey, i just got an 06 mr, and want to get an hks carnon-ti exhaust. can i get the hks downpipe with that also? eventhough it is 2.75 inches? im still new with all this stuff, and am not completely sure.
any help would be appreciated.
Thanks alot
Thanks alot
I have the same exhaust and the same DP that you are looking at they work fine together with and Invida TP. If I was you I would go with a 3" Dp though thats what I am going to be changing to soon.
The HKS Carbon Ti does not fit a IX MR properly, it's highly likely it doesnt fit a IX either. The resonator in the cat back section will rub against the drive shaft carrier bearing. You can hammer the resonator so it wont rub or your can just buy a better fitting exhasut for less money. I can't believe that they sell these POS's for the money..
Even worse I cant believe that so many people give this junk exhaust a good review. Want a good JDM exhaust, get the Tanabe Concept G Blue, it's cheaper, flows better, and fits perfect. Everyone else, PLEASE quit recommending this poorly designed exhaust for IX owners.
Search HKS and RUB
https://www.evolutionm.net/forums/sh...hlight=HKS+rub
https://www.evolutionm.net/forums/sh...&highlight=HKS
Search HKS and RUB
There is a extremly cheap and simple solution to this problem which is taking a super thick zip tie, pushing the left rear exhaust bushing to the right a little and putting the zip tie on the exhaust hanger so that the bushing can not slide to the left anymore. this will put the resonator out of the way of the drive shaft for good.
I have had ZERO problem swith this since I got the gasket replaced. The exhaust has good flow, DOES fit well, and sounds great too. IMO AND I AM SAYING IMO ONLY. Every Tanabe exhaust i have heard sounds like complete crap after it breaks in. Snap crackle pop
really? becuase my hks carbon ti fits my ix mr just fine.
CR7-Style: i would go with a 3" downpipe. i have an invidia and it fits quite well with a perrin test pipe and my hks carbon ti.
i have the tanabe concept G Blue turbo back system....its the best investment i bought for my evo ix.....great ground and body clearence.....fits really good and you can feel the hp improvement right after u install it......
dsmdeliveryboy
11
Nov 26, 2007 09:01 PM
Unforgiven
11
Jul 31, 2005 09:44 AM
