Installed Oil Cooler Fan: Pics Inside. Cost:$94 Benefit:10-15 degree drop
Well I have been thinking about doing this for a while and I finally did it. Believe it or not, I only found 2 threads speaking about this. One guy did it but used a pusher fan instead of a puller fan and the other thread was mine
Background: I wanted a way to cool my oil cooler on demand with additional air while still retaining a stock look with stock parts at an affordable price. I found a fan that spal sold that was cheap and small enough to fit in the area behind the oil cooler and it flowed enough air to make it worth while. The fan I found pulls 313cfm of air which impressive for a fan that small. Also, choosing the puller type fan is important so that you don't block the oil cooler.
Ok so here it is: (Pictures are attached below)
The stock dimensions of our stock oil cooler are 6'' x 5'' x 1/2''
The fan in this picture is Spal's 5.2'' puller fan. Part# 30103011. It costs $67.95.
http://www.spalusa.com/fans/automate...52_paddle.html
It is located under their atv/motorcycle fans section
One suggestion: I recommend calling them and ordering it over the phone. Their website at the moment only has the "push" type fan available to order online. So be sure and call them so that you get the right fan.
This is the switch I control it with. The other one is just a dummy switch. My '05 did not come with fog lights or HIDs so I put these in place of the blank block off plates.
And I have my gauge cluster here from 42 draft designs to monitor my oil temps.
Cost: $67.95 for the fan + $8 for the switches + $8 for misc. things like wire and connectors etc + $10 for shipping = About $94.
Benefits: When driving in town with the fan switched on, I have not yet reached oil temperatures above 200 degrees. They stay right around 198 or so which I think is perfect. This is also a good cheap mod for those of you who autocross. RPMs are high and the car is no moving very fast, so the extra air flow helps out. $94 compared to $500 for a new Greddy cooler for this car is a good cost saver.
Should I put this in the write up how to section?
I cant see the 2nd pic either.
This is an excellent write up though. Its interesting that none of the track guys use this as I would think you would want to keep the oil from over heating.
Interesting idea, man seriously. At a certain MPH though, aren't you just hindering rather than helping the cooler? I understand it pulls the air in, but I doubt it can keep up with the incoming air when traveling at high speeds. And don't you want to keep the oil at normal temps? You don't want to cool it too much, right? Educate me, I'm just curious as I really think this is a good idea.
Oil fan
When I get off the highway, the temps are usually around 230-240. The fan cools the oil down much quicker also.
Its a cheap mod that helps, I think.
