Oil Cloud on decel. HELP!
Alright here's the deal I work for MAPerformance and we put my engine together a few weeks ago(Evo VIII):
-JE Pistons(out of a crankwalked 2g with hardly any miles on them, block was bored to these pistons)
-JE Piston Rings(Brand New)
-Cometic Head Gasket(Head Decked)
-Eagle Rods
-BC 280's
-BC Springs
-Supertech Valve Seals
I'm running AEM and we tuned it the other night and now after a pull it smokes hard core oil smoke on decel and only on decel. During the pull and during regular(no boost) driving there is no smoke. We don't think it's the turbo(stock) because there is no shaft play and why would it only smoke on decel.
Anyone have any ideas?
-Eagle Rods
-BC 280's
-BC Springs
Former Vendor
You may have a oil land ring problem, or bad valve seal, or turbo seal. The reason for smoke on decel is vacuum.
Watch your plugs, and watch the turbo inlet for leaks. youll find it soon.
I would be suspect of the rebuild.
Anyway, did you check the stem seals in the head? They pull oil into the combustion chamber when leaky and produce oil smoke on back-off.
when you check compression, the valves are closed, so a leaking stem seal won't show up. But under decel, the intake manifold and cylinder itself see vacuum, sucking oil past the valve stem seal if it's bad, and into the combustion chamber.
