fq400 turbo name? where to buy?
Its a garrett DBB Turbo, I wouldn't get it. Mitsubishi would charge an arm and a leg for it and you wouldnt even be able to run it without upgrading the fuel system, and getting new tune. In the end it will cost thousands of dollars, I would just go with a turbo kit from someone else
If the images are correct the FQ-400 was equipped with a stock-looking, cast exhaust manifold with provisions for mounting a stock-type heat shield, as well as the incorporated factory ALS plumbing, in addition to the one-off Garrett turbo with the integral gate. From the looks of it, the turbo must have been configured with a custom cast(by Garrett?)turbine housing, huh?
