ix cams po11 code
#123
It can since the target value is a little harder to reach at idle when there is low oil pressure. Its easier to set it normal and not try for the lopey idle or just turn the code off all the way and be done with it.
#124
just checked the thread. now i remember: i did have a bad idle. i was only running Tomei 264 cams. nothing crazy. the car would idle strangely (not like a "big cam" idle).
they will idle rough due to a change in vacuum. the car needs to be tuned to smooth it out unless you like it that way.
#126
#127
i think i put my similar problem in the wrong section but trying to get help with it.
https://www.evolutionm.net/forums/ec...ine-build.html
OneEyedJack
47
Sep 9, 2010 08:30 AM
