HKS Super sequential Vs HKS Super SQV Racing Single Valve
The SSQV is not junk. It get's a bad rep on here because 99% of the time people ask about it because of how it sounds. It is a very good product that has proven to work good on many diffrent vehicles, but it is also expensive and can be a little tricky to install. Some of the mounting flanges made to work with the SSQVs have the grove for the 0-ring cut too deep and will not seal. You have to get a thicker o-ring then what the SSQV comes with, or you can get creative. I epoxied mine into the flange and pressure tested it. You're going to need to get a recirculation fitting for it as well if you are using the MAF. There are other valves out there that work just as good, are less of a pain and won't hit your wallet as hard. However, if you really want an SSQV, it will work just fine. I personally would have gotten a forge, but I had an SSQV already from my other car.
NOTE" that all the people saying its not junk have less then 50 posts, you guys should do some research, I'm sure its not junk, but they have better for cheaper, if you must have the hks ssqv over another better brand then get the recirculating kit with it.
The only pull type BOV's i know of are the HKS and the Synapse..... TIAL is NOT a pull type...
The HKS is NOT a bad BOV, as people on here have said, set up correctly it works well! people that say it is 'junk' really have NFI if you ask me. It is expensive but that aside it is a good BOV, FULL STOP.
