Dyno tune tomorrow
Six the tune is dialed in for road racing. I am in no way a big drag drag racing freak. Bnice would be better able to go into my MAP details but I think its running 12deg of timing at redline. Mase actually lowered the boost and bumped the timing from what it was when I went in.
I would have been happy at 320-330whp so you can imagine I am pretty excited at 350whp!
to be honest he retarded a degree @ 3500 & @ 7k, lean out the afr's in the higher load cells, & drop the boost a little.
naw the tune is conservative/safe not on the edge, not going to give out to many details since its not my map.
evovin i didnt take my car just went up there with bonestock but i'll be up there soon to dyno tune my ride myself.
no offense but I was there I think i seen the graph really careful. wow let it go , relax is steven happy with his car YES thats whats matter the most.
bonestock said he thought the tq would be higher, its not really my place to be saying stuff about his ride. thats all
Actually I goofed when i printed this dynochart.
The reason why hp/tq isnt crossing at 5252 is because I dont have the scaling the same for WHP and TQ. If you look at the dyno chart scaling, you will see they are close, but not the same...
The numbers etc are correct, except when i scaled the chart, I must have scaled them differently.
The torque is exactly where it should be, you have to use the right margin scaling. it made 300 ft/lbs of torque. and 350 whp.
Bonestock, it was great meeting you guys, hope you had a good trip back, and glad to see your happy with the results . Id be happy to save a copy of a dyno chart with the same scaling. i didnt realize it when i gave it to you lol
Mase
Looks like this DD is setup to read like a dynojet.
Curves look great though, nice flat torque.
Glad you are enjoying the GMBCS bonestock. If your boost is fluctuating a bunch I would also make sure the BDEL and error correction is dialed in tight.
Did a tuner really just say this? 5252 always, unless the tq/hp have different scales on each side like this chart.
Funny you should say that. I asked Mase that very question and his response was that it was not.
The boost problem is the BPV atleast... I hope.
It is an interesting torque curve for a stock turbo for sure. Very flat. I suspect some of this is due to the tuning using the GM BCS, and some is due to the fact that you're only spiking to 21psi initially. Kind of a trade-off here - more top-end with less low-end torque. I personally prefer to have a bigger torque spike initially on the stock turbo for having fun on the streets.
