spark plugs????
Old Jan 22, 2008 | 01:55 PM
evogrl's Avatar
spark plugs????
i am having a major popping problem at high rpm/boost and it didn't start doing it tell i put some new plugs in it if it is the plugs witch ones should i get my list of mods are
hks hi power turbo back
hks ssqv bov
dejon tool mbc set at 21psi
k&n intake
Bigger FMIC
please help i need this fixed tonight thank you very much
Old Jan 22, 2008 | 02:00 PM
travman's Avatar
what did you gap them at?
what plug did you put in?
Old Jan 22, 2008 | 02:05 PM
scottatyamaha's Avatar
brp8es gap them to .026 and also do you have a tune?
Old Jan 22, 2008 | 02:06 PM
Also why dont you use your $4k code scanner to fix the car for you....lol. '
https://www.evolutionm.net/forums/sh...10#post5142710
I am just giving you a hard time.
Old Jan 22, 2008 | 02:38 PM
travman's Avatar
I don't think a colder plug is needed with those mods, the 7 heat range plug (BRP7ES) would be better imo.
Old Jan 22, 2008 | 02:44 PM
evogrl's Avatar
no i don't have a tune yet tax return time i'll get one it had the irdiums in it before and ran fine i put champion platnums in there that's all i could get
Old Jan 22, 2008 | 02:51 PM
travman's Avatar
Get a set of std. NGK plugs (they dont have to be iridiums) and get those swapped out immediately. That is most likely your problem more than anything......
Knowing champion they aren't even the right plug or correct heat range
Old Jan 22, 2008 | 07:00 PM
What! No tune??? You have a $4k code reader and said in a previous thread that all of us that bought $20-$35 code readers were cheap and that you only bought the best for your car, yet you have not bought a $50-$200 tune???? I dont understand people they spend the money for mods on their car and then dont even pay out the money for the most important thing they can do, a tune. You car hates you
