2.3l stroker or 2.1l destroker
#32
I'd be curious as to why the crank broke instead of making the assumption that ALL 4g64 cranks are bad. There are lots of shops that use "crank kits" to build their engines which are nothing more than re-manned pieces and are often cracked right out of the box. Add high RPMs and boost to that and you end up with a broken crank. Done right, the 4g64 cranks work fine.
Was the motor balanced?
Proper balancer installed?
Correct clearances?
Balance shafts?
Correct clearances?
Balance shafts?
#33
Correct clearances?
Balance shafts?
Correct clearances?
Balance shafts?
Aristocrat Dave
EvoX 'For Sale' Suspension / Brakes / Handling
381
Nov 15, 2017 09:14 PM
Aristocrat Dave
EvoX 'For Sale' External Engine / Power
339
Aristocrat Dave
281
Nov 15, 2017 09:13 PM
EVO(boss)
Oct 23, 2011 01:49 AM
dambikeracer
57
Mar 14, 2010 07:43 PM
