02 sensor install help!
un bolt the heat shiled bolts and it should be right there and disconnect the sensor coming out under the car then un plug the sensor from the test pipe or whatever you have then hook up the new one like you took out the old one
yea if i remember correctly just follow the heat shield all the way up and down the car. i think there was only one kind of tricky bolt to get to. but worry about that one last. not alot of room to manuver
Wow finally done! PITA! I just took out the bolts for the lower heat shield except the one thats right next to the a/c compressor. That looks impossible to get to . After removing 3 bolts I was able to move the shield around to get the socket in there.
bwagner31
Jul 23, 2010 07:40 AM
ChuckP
24
May 24, 2007 08:47 AM
