Building a trans to handle 5-600hp
My Evo 1 box has a bad 5th syncro and needs to come out, so i figure while its apart is there anything that can be done to improve the strength and shift quality? The engine is a built 2L running a GT35r with all the usual other parts, its making anywhere from 400 - 550whp depending on the tune and fuel used, i dont intend to drag race or launch the car hard or generally beat the hell out of it. From what ive been told the early trans have smaller gears than the newer age ones, this is a worry. I've just recently bought the car and the previous owner has destroyed a very expensive PPG dogbox drag racing the car, but hasnt had too many dramas with a standard box on the street .
For a start im going to get all the syncros replaced, what else is necessary?
Its easy for all of you in the US, as you can just send your trans to shep or TRE, but theres not any EVO/DSM specialists in Australia
heres what shep does in their stage 1 rebuild on EVO's and DSM's
The Stage 1 is a perfect solution for those seeking a tough upgraded replacement for their DSM. Your trans will be painted with aluma blast to make it look like new.
Included Features:
* Shims for setting preload
* New Nylon Shifter Pad
* New Center Diff Side Shims
* New End Nuts
* New Roll Pins
* New Intermediate Gear Bearings
* New Input Shaft Bearings
* New Input, Output, and both Drive Shaft Seals
* New 1-2-3-4 Synchro Springs
* New 5th Gear Synchro Rings
* New 3-4 Synchro Rings
* New 1-2 Hub/Sleeve kit with Double Synchro Rings
* New Shep Trans Spec 2nd Gear
* New 3-4 Fork
* New 1-2 Fork
* 1990 pricing
* New engine dowels
We take your trans and apply all applicable tsb's and updates as well as modify the oiling system and a few other tricks to make it shift. This trans build is used by the quickest and fastest Evo's around including both the AMS drag car and time attack car, AL (dynoflash), Buschur Racing, Curt Brown, Pruven Performance,Dan Bajalis , Proco Evo and many more.
Included Features:
* New 3rd gear synchro
* New 1-2 shifting sleeve
* New 2nd gear synchro
* New 1st gear synchro
* New 4th gear synchro
* New 3-4 shifting sleeve
* New 5th gear synchro
* New 5-R shifting sleeve
* New seals , shims and snap rings
* New 3-4 fork
* New input shaft bearings
* New high strength roll pins
* New Reverse synchro
* New 1,2,3,4,5,R synchro springs
* Neodymium magnet
and TRE for the EVO's
This is our Stage 1 rebuild service for the Mitsubishi EVOLUTION 5 speed. It is the bare minimum of what we offer. This rebuild receives all current Technical Service Bulletins updates that are available from Mitsubishi and we use updated part numbers where applicable. Your transmission will receive modifications to improve oiling to critical parts and machine work that improve shift quality and increase the service life of the transmission. If you're wanting an excellent shifting transmission that has proven itself to live in a 9 second EVO this would the way to go, however, we can build them even better so check out our other rebuild stages. Click here to learn more on how things get done at TRE.
Parts being replaced:
New 1-5th & Reverse synchros
New 1st-2nd sleeve
New 3rd/4th sleeve
New 5th/Reverse sleeve
New 3rd/4th shift fork
New Input shaft bearings
New output shaft bearings
New oil seals
New synchro springs
New heavy duty Neodymium trash magnet & magnetic drain plug.
New snap rings, heavy duty double roll pins, bearing shims and all the other non-reusables.
5 SPEED EVOLUTION STAGE 1 REBUILD = $900.
Included Features:
* New End Nuts
* New Roll Pins
* New 3-4 Fork
* New 1-2 Fork
* 1990 pricing
* New engine dowels
Included Features:
* New 3-4 fork
* Neodymium magnet
New 1st-2nd sleeve
New 3rd/4th sleeve
New oil seals
New synchro springs
yes, i had one of their gearsets in my wrx, unfortunatley they only make a dogbox for the evo's no helical syncro sets.
Can anyone point me in the right direction?
Jeremy@MWPerformance
Feb 8, 2012 04:39 PM
ChrisCarey
25
Sep 8, 2011 06:55 PM
APM Racing
Midwest Region
22
Jun 1, 2011 02:33 PM
stamlon
For Sale - Cars For Sale
12
Apr 1, 2011 02:08 PM
TTP Engineering
Evo 'For Sale' Engine Internals and Drivetrain
79
Dec 1, 2009 01:34 PM
