All headgaskets are not created equal
Old Feb 8, 2008, 08:00 PM
  #31
TTP Engineering's Avatar
Cometic is garbage. Locals have used it and have had horrible experiences with it. Steer clear of it.
The only headgaskets we stock are OEM and Cosworth available in various thicknesses.
Old Feb 10, 2008, 03:08 PM
  #32
JKav's Avatar
Originally Posted by lemmonhead
more layers is not necesarly better. thicker head gaskets could cause problems by adversely changing the geometry of the head-block interface on the intake manifold , this is on Vee-type engine though.
But for out inline engines it could also subtly alter cam timing. but worst of all it could degrade the squish effect in the combustion chamber which can be greater pro-knock factor!!
your best bet is to o-ring they cylinders by machining a shallow groove into the fire-ring area of the block or head around each cylinder bore then installing gapless machined-steel rings or steel wire into the groove.
I don't think he's talking about a thicker gasket, just more layers. I'm fairly certain the VIII and IX gaskets are the same thickness overall.
Old May 26, 2008, 04:29 AM
  #33
EvoM Moderator
joedr's Avatar
One thing I noticed is that I can not get Cosworth STD bore gasket.
Sorry for this question but.... What do you do on STB bore application? Use the 66mm?
Old May 26, 2008, 08:25 AM
  #34
SWOLN's Avatar
You mean 86mm? I'd call Cosworth, maybe they have some insight.
US Office
Cosworth Inc
3031 Fujita Street
Torrance
CA 90505
USA
Phone No : +1 310 534 1390
Old May 26, 2008, 10:13 AM
  #35
EvoM Moderator
joedr's Avatar
Oooops! A typo! I meant to say 86mm.
I will give them a ring!
Old Jul 28, 2009, 09:36 AM
  #36
honki24's Avatar
I'm bringing this back from the dead because it is amazing. I am looking into buying a HG right now and this has been a great help. I'm going to look into the IX OE gasket.
sterlinge
Sep 2, 2016 01:30 PM
DSPORT
Oct 13, 2015 01:41 PM
Speed Element
Feb 27, 2008 11:34 AM
Enjoi926
For Sale - Cars For Sale
Dec 22, 2006 08:12 AM
A-SPEC
Oct 11, 2005 07:07 PM
Quick Reply: All headgaskets are not created equal
