MR 6-Speed Transmission Drain/Fill Plugs
Just to let you guys know, the drain and fill plugs on the 6-speed transmission are different. They require a 10mm allen. I recommend a socket-style allen key, but I was able to remove both with the normal "L" shaped allen wrench. The fill plug is removed easiest from the top of the engine bay when using the normal "L" shaped allen wrench.
The 6-speed also uses a little less fluid than the 5-speed. Around 2.5 quarts should fill it nicely ...
The other drain plugs are all 24mm and the fill plugs are 17mm, just as they are on the normal 5-speed cars.
(I know this is posted in a couple of other older threads on the forum, but I thought a specific thread would help searching.)
RendragSemaj (Oct 22, 2018)
Does anyone know where to find the evo IX 6 speed transmission fill / drain plug / bolts? One of mine is stripped something awful. Cant seem to find them online anywhere
I bought some at Hillco fastener warehouse inc. 714-657-7455.
Its an 18Mx1.5 drain plug. The replacement I got just had a regular bolt head on it, not the allen. I also did a somewhat complex pump/cooling setup so I ended up with special hollow plugs for flow to lines.
The part number I have for the regular extra drain plug I bought was
AV15529
If you just google that a bunch of auto supply places will come up to order online. Its relatively standard.
AV15529
AV15529
AV15529
For non SoCal peeps, they will have to order it online of course, but man that place is awesome, has!
Also, King Bolts is decent too, but not as good as Hillco though.
Good on you, fireroasted.
For anyone else that might be interested, that part is actually made by a company called 'Auveco' - I actually managed to find a box of 5 on ebay.
chaotichoax
32
Feb 11, 2020 09:00 PM
hccyong
10
Jul 13, 2019 04:47 AM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
turboDan
86
Oct 26, 2012 12:47 AM
