Torco Accelerator Fuel, answer to unleaded race gas??
Has anyone tried this.. would this be a good option for people who can get race gas locally?
They are claming 107 oct from 93..
http://www.exoticperformanceplus.com...html?item=1010
http://www.rwtd.com/detail.aspx?ID=70
I honestly don't think a tiny bottle of anything will make a huge difference in a few gallons of pump fuel. Lets do the math ...
If that stuff were, say, the equivalent of 130 octane fuel ... lets mix in 32oz (.25 gal) of the additive in to 7 gal (1/2 tank) of 93 octane ... you end up with 94.2 octane fuel.
Most of those additives are based on a mix of Toluene and Xylene (and some other things), which are 114 oct and 117 oct respectively. Use those numbers with the same calculation and you get closer to 93.8 oct.
So, in short, those additives may make a slight difference, but they are in no way a replacement for race fuel. Also, you are much better off dropping by Sherwin Williams and getting 5 gal of straight Toluene for ~$37.
(Edited for correct calculations)
Last edited by TouringBubble; Feb 4, 2008 at 02:34 PM. Reason: fixed calculations .. had based them on .5 instead of .25
I will agree ... a difference in 1 octane point can be noticed while tuning. That's about what this stuff will give you. However, it's doesn't give you 107 octane fuel ... probably not even mixed at a 1:1 ratio ...
Did you have any issues with your plugs and O2 sensors? I know several people who have a residue/coating on their plugs/O2 sensors after using it. Their resistance to knock did improve, so the stuff does work.
I have beeen using torco for quite some time with great results. On my pumpgas map when my zero knock limit is around 23psi a can of torco raises that limit to 26psi easy with the ocassional one knocksum during overboost but that's it. 3psi extra its huge for our cars in terms of extra power.
I remember a guy tested torco in a lab and it showed that in ten gallons of 93 a 32oz can of torco raised it to 96.5 octane. Its not the 100 octane they claim but 3.5 full octane units its huge. Plus you have the extra safety.
As far as the red residue is concerned never had issues. As far as the price is concerned a five gallon jug which is equivalent of 20 cans can get you 20 fillups which in my case they last for over 4000 miles of driving (200 miles minimum per tank times 20 cans).
Dave
the only way this could have happened is if the "93" in question was simply really good 93. The pump octane rating is in fact a minimum rating, so that 93 could be higher than 93 initially.
Yeah, that is huge ... technically 236.5 octane huge. I'm sorry ... I can't believe that.
It funny that this is being posted today because Last night I was doing a little research and found this: http://volvospeed.com/Reviews/octane_boosters.html
Check out the Lucas booster. From the article: "To date Lucas octane booster is the only booster tested that had significant results with only one bottle in the tank. One bottle is enough to make 10 gallons of 96.6 octane out of 93." If you do the math that's roughly 4 dollars per gal for 97 octane( 8 bucks a bottle and 3.20 gal.). Not too shabby.
I ordered 2 cases
I ordered 2 cases
My friend is a distributer of Torco. He tested it with 10 gallons of Chevron 91 and 1 quart of Torco and it came out to 96.5 octane. He runs Torco in his 800whp Corvette, for 3 years now. He run 96 octane all the time. If it is good enough for his vette it is good enough for an Evo. It is very popular on the Corvette forums.
I used it on my STi. I loved it. DynoFlash tunned my STi and he could not believe 1 quart could do that. It does turn your plugs and tail pipe orange but it doesn't affect anything. I will be having my Evo tuned to it in 2 weeks.
Here are his test results.
