403whp Mustang Dyno FPgreen
I retuned a local guy with 110 octane couple weeks ago with a FPgreen.
Before, he did 374whp/328wtq on 100 oct, 25psi peak.
Retuned on 110 octane:
2005 Evo 8
Mods:
TBE no cat
GSC S1 cams
Stock cam gears
Tubular header
FPgreen turbo
Tubular 02 housing
Sun HyperForce
GST Open Filter
Denso 720cc injectors
Fuel Pump
FMIC
Boost Assembly (ecu-controlled boost)
110 octane
Factory ECU and MAF
403whp / 360wtq
27psi peak to 23psi at 7400rpm.
Low reading mustang dyno. 400 is basically the "holy grail" on this dyno on a turbo like this. First FPgreen locally that has done over 400.
91 octane fpgreen equipped 8's and 9's do approx 325-345whp on this dyno, depending on mod level.
Keep in mind this is "sane" boost, not the 30+ psi I see others doing, not that 30+ is a bad thing, but this guy tracks and autox's this car so I felt 28+ would be pushing it.
There is more left in it if it was a more aggressive tune. The tubular header added a bunch of lag to the car but I'm sure it isn't a big deal with the power being what it is.
Oh, the car only weighs 26XXlbs without driver. Rocket for sure.
2005 Evo 8
Mods:
TBE no cat
GSC S1 cams
Stock cam gears
Tubular header
FPgreen turbo
Tubular 02 housing
Sun HyperForce
GST Open Filter
Fuel Pump
FMIC
110 octane
Factory ECU and MAF
403whp / 360wtq
26XXlbs!! thats light..... What has been done for the weight reductions? Is it an RS? Very curious. This has to be fully stripped and gutted.
wow thats good numbers to be on a mustang dyno. im pretty impressed by it. im in the process of doing my build with a green w/ forge actuator, jun 272/272 combo with springs and type 1 retainers, ble lifters and new stem seals and seat locators. the rest of my mods are in my sig. cant wait to see what i put down when i get done.
