Spring/Retainer Install HELP!!
Ok, well I tried to install my springs tonight, got 1&4 cylinder springs and retainers off, but the tool we got at NAPA wouldnt work. Well, I was reading the HOW-Tos, the tool I saw that was recommended by some shops was this one: http://buy1.snapon.com/catalog/item....re&dir=catalog so my question is, will it work to install the BC Springs and Retainers because they seem stiff as hell! If it will work would be great because I get a discount through school, but I need to know before I buy its possible to get enough weight behind it to compress those springs? Thanks!
I've used/have the Snap-on tool and it works. I did the rope trick where you feed in about 10 or so feet of rope through the spark plug hole and then turn the piston up against the rope. The retainers stick pretty good - maybe you alread know this and then come loose with sort of a snap. So, using a tool that you strike - I dunno if that would work. Plus, you had better have something under there to stop the valve. I assume you are working with head on block.
well the pistons on 1&4 are TDC and didnt move at all when we took the springs and retainers off. We got them off with a 13mm deepwell with a socket magnet inside of it. They came off fairly easy. We bought a spring compressor at Napa and there is no way in hell it would fit. I get 55% off with snap-on through scool so I was looking at that one and the lever type. But if this one will work its 1/4 of the price! So to put it back on, you just load the keeper inside the retainer and shove it over the valve till you feel it click on? Have you done it with aftermarket springs and retainers because the BCs are alot stiffer than the stock ones?
I think you're suppose to use a spring compressor in conjunction with that tool...
EDIT: nevermind.... however I found these tools making their own tools... LOL
http://www.youtube.com/watch?v=BtNMRWDsvbw
The work I did was on a DSM with stock springs. To load the keepers I magnetized a small screwdriver by running it over a magnet a few times, just enough to suspend the keepers so I could drop them in place one at a time while all the time holding the spring compressed with the lever tool. It was great arm exercise as it was.
no, it says that you can do the remove and install with this tool, Im just trying to make sure that I can do the BC springs with this (or any aftermarket ones). That guy is a ***, he says in the eplanation for stupid people who cant do it, I dont think I would let him touch my car with that thing! And the tool I need is for doing it in the car, Im not pulling my head!
You shouldn't have any problems with the BC springs and retainers. Now im having a hell of a time with the Supertech 120lb springs
Chris
EDIT: It looked like that guy in the video actually was using the tool upside down. The adjustment part of the clamp is supposed to be what goes against the valve face. Here is a picture of the one i use. They have new ones you can get now that connect to a drill to compress the spring. Its really easy once you have the right tools!
Yes I read the HOW TO, I also saw where a few of the people recommended this snap on tool! I know what the lever tools are, however they are $140! This tool I can get for $20 with my discount through Snap On! I just need to know if it will work with aftermarket springs and retainers! I am going to school for High Performance, I know how to do this stuff, im just trying to see if this tool with work for what I need it for! I dont want to F anything up with makeing a ****ty tool to use! If I have to buy the Lever Compressor I will, but for $100 less, I would much rather use this if it will work!
