RRE X Clutch Or Exedy Stage 2
Cant make up my mind what I want to do for a clutch. My car is stock turbo and eventually will be upgraded to a green or a 50 trim. So it wont see more than 425 whp for my entire time of owning the vehicle.... More than likely will be around 370whp for the life of a clutch
I have 45k on a stock 03 clutch original clutch! It doesn't have much life left, it releases extremely late but yet isnt slipping yet...
I have a warrantyon the drivetrain until 75k miles so Im considering the RRE X or RRE no name clutch, w.e you want to call it because of the fact it looks stock and can get away with it.
Is it a good clutch, Idk ive heard mixed reviews. I like the reviews foran exedy stg 2 but my already****ty warranty would be shot...
I wont consider an Act clutch due to having alot of issues with thecompany in the past
What do you guys suggest I do
was that with tracking??... I forgot to mention i dont track the car, maybe 10-15 launches a year from a "private Road"..... i hope to take it to thedrag strip forone or two runs thisyear... just mostly spirited driving
Adjust your clutch rod......... if its not slipping & you dont drive that hard it probably still has life left. mine showed similar symptoms & when i removed it @ 47k or so there was roughly 30-40% wear surface still left....though my Pres plate & flywheel were toast from the larger turbo, if i had still been around stock power levels i believe it would have lasted to 80k ......
EVOIXNooB
May 6, 2014 10:02 AM
BlackOpsEvo
Oct 4, 2011 07:51 PM
Serge03
30
May 11, 2005 05:30 AM
