What is the deal with Full Races Twin Scroll?
Old Mar 22, 2008, 10:06 AM
  #31
CleverUserName's Avatar
Originally Posted by evodan2004
do you realize the issues i had. 1 issue was something to do with the full race kit. i needed an anti surge cover. all the other issues where not full race or full race kit involved. i had a list of problems or should i say things that needed to be fixed/changed. nothing to do with the kit..
the car is being tuned now. i been driving it everyday. and very hard. im a busy person and do have a job. dyno results are not long away. so befor you think the kit is junk or whatever your thoughts are i would not jump the gun.
did you get a chance to get it tuned? how's the surge? got any dyno results?
Old Apr 3, 2008, 11:40 AM
  #32
HaVoC RR's Avatar
no surge ken..it pull like a **** and still on a flash...
Old Apr 29, 2008, 05:21 PM
  #33
mokompri's Avatar
Originally Posted by DTM
My issue is I would like to know why people continue to claim that (hypothetically if there were such A/Rs) a .63 A/R of a standard open volute would mean that an equivalent would be 1.01 for example.
The important difference to note about TS and single scroll turbine housings is that for the same A/R, the TS is a slightly
more restrictive turbine housing. Hence on the TS to make up for this, they usually use/recommend a larger A/R.
The reason why it is more restrictive is this;
On a TS every exhaust pulse only travels down one scroll of the available two (on a properly setup TS anyways). A/R is area/radius, and since each scroll on a TS has only half the 'area' but maintains the same radius, we get a halving of the quoted A/R. so effectively each exhaust pulse only sees .315 A/R as it runs through the turbine housing.
On the other hand exhaust pulses on a single scroll housing see the full quoted A/R, and hence each exhaust pulse has a larger/'higher flowing' area to accomodate it.
you cant really say they are equivalent (ie .63 TS to a 1.01 single) because they have different dynamics, but i think what people are trying to say is they have similiar overall flow capabilities.
Old Apr 30, 2008, 07:20 AM
  #34
Philthy748's Avatar
People get so focused on a peak numbers and it's everywhere else that a TS really kicks a$$... throttle response, boost threshold, power curve, etc... A larger turbine housing is certainly ideal on a TS, but like mokompri stated above, there are different dynamics between TS/Single Scroll which facilitates different component requirements!
Old May 20, 2008, 07:47 AM
  #35
500hpOnPumpEvo's Avatar
This calls for a Video!!
Old May 20, 2008, 07:49 AM
  #36
EvoDan2004's Avatar
Old May 20, 2008, 07:51 AM
  #37
EvoDan2004's Avatar
im soon getting a retune after i add this pile of parts i have sitting here.
Old Jun 16, 2008, 06:33 PM
  #38
tunermt's Avatar
Garrett is currently working on a variety of different sized AR twin scroll housings for all the GT series turbos. This should allow all the twin scroll set ups out there to be matched for what ever the final user would like (spool vs. top end)
Old Jun 22, 2008, 09:29 PM
  #39
Babs's Avatar
i think there are better options than full-race...quality...but overpriced if you ask me. i believe peakboost is coming out with one soon
Old Jun 25, 2008, 12:39 PM
  #40
tunermt's Avatar
full race parts are not cheep by any means however you must remember you get what you pay for. I have ran a full race manifold on my Nissan for years and LOVE it! it was hard to fork over the cash but I know I will never need to worry about my manifold again (the only life time warranty I have seen)
I have looked into peak boost in the past and noticed there manifolds seem to be (for lack of a better term) knock off full race parts with lower quality standards. I don't mean to dog on peak boost I would just half to say it is not up to par.
evo8lento
Jul 27, 2016 02:19 PM
5LEEPERISAH23I
May 11, 2016 03:47 AM
SloEvo12
Mar 28, 2016 02:03 AM
tsi20gawd
Mar 5, 2016 07:40 PM
Airflow86
Oct 25, 2014 11:23 PM
Quick Reply: What is the deal with Full Races Twin Scroll?
