apexi s-afc II and Blow off valve quetion
i just installed the s-afc everything is fine but what setting should i put to go with the HKS SS Bov so it could stop the low idle and stalling.?
Awkward. Try searching and seeing if anyone else has the same problem. I would still definitely keep it recirculating though since the car does like to run with all the air it has counted through the MAS.
EDIT: Oh yeah, also, check your AFC settings and make sure nothing is freakish about them, any fittings and lines that might have come loose etc. It could probably be something that you just forgot to overlook.
ski10804life
Jun 28, 2007 07:03 PM
LostSoul Evo
Jul 26, 2005 05:46 PM
wheming
Mar 16, 2005 05:56 PM
