need help greddy profec b spec II wiring
1 Post
A friend practically gave me a used Greddy Profec B Spec II electronic boost controller he doesn't use.
the problem is that the wiring harnesses on the back are damaged.
If you're looking at the back of the controller unit there's two harnesses
left by the boost nipple it has two prongs...I suspect one may be power and one may be ground? which is which?
on the right another two pring connector. I suspect this connects to the solenoid wiring, one white and one green? which is which?
if someone could look at the back of their unit and explain to me in order from left to right which wire goes on each prong I think I can solder some wires on there and get it working.
thanks in advance!
thanks in advance!
Does this help?
http://greddy.com/img/PHP/products/pdf/682.pdf
I went here.
http://greddy.com/tech/
When I had my Profec B, I saved a copy of the .pdf manual and gave it to the guy I sold my unit too, since I did not have the original manual.
I went here.
http://www.greddy.com/img/PHP/products/pdf/682.pdf
The diagrams show how it should be set up. It appears you can order the two wire harnesses as well:
http://www.greddy.com/products/displ...SubCategory=51
-Paul
-Paul
1 Post
thanks guys, I just made a power/ground harness and the unit will not come on...it's dead
oh well, I'll buy another unit and have a spare solenoid maybe.
fusionchicken
Evo X How Tos / Installations
54
Dec 12, 2014 10:18 AM
h4ckluserr
Sep 7, 2011 12:09 PM
EGbeater
Jan 11, 2010 06:27 AM
Mellon Racing
16
Feb 11, 2008 01:16 PM
