ACT HDSS Needs Adjustment?
I had an ACT HD SS (heavy duty pressure plate w/ street disc) put in recently and it was awesome.
I say "was" b/c the buttery-smooth shifts and grabby pickup of the clutch are suddenly gone - I'm back to the notchy and sometimes grinding shifts, even with the clutch pressed fully to the floor when changing gears.
This has to be an adjustment issue that's a direct result of the break-in period, right? The notchiness started as I got the clutch warm (I was bedding my brake pads so did about 20 or so 10 mph to 60 mph to 10 mph cycles).
I'm very happy with the clutch but want to get it "back" to the way it was when it was brand new (in terms of shifting smoothness and engagement, anyway).
Of course, I followed directions and haven't done any really hard shifts or hard acceleration during the clutch breakin period. I've also noticed that the pickup point now seems to be further from the floor than when I first got the car back.
I know there's a screw that can be adjusted on the clutch pedal but I want to be sure that's all I need to change.
Recommendations?
Thanks in advance!
Recommendations?
Thanks in advance!
every clutch needs to be adjusted, like Revmoto said check out
http://evomoto.com/tech_info.php?tec...5a333ea59eb80f
link to the site
Cheers!
link to the site
Cheers!
link to the site
Cheers!
link to the site
Cheers!
On a pure curiosity basis - what is happening mechanically to the new clutch so that it requires adjustment? Is it really wearing thinner that quickly?
Do you need a special wrench to adjust this? I cannot get my pliers (or any other tool for that matter) to get into a position to loosen the lock nut, much less adjust the pushrod. There's nearly no room to maneuver at all.
How are you guys doing this? Just sheer finger strength?
Use a box end wrench on the nut to loosen it enough to get with your fingers. Then "play" with the pedal while turning the rod to adjust it. By playing with the pedal, I mean moving it slightly to release pressure on the rod. You will see what I mean. Tighten it back up, and youre done.
I am having similar issues with the exedy twin, however, i think my clutch pedal adjustment is already maxxed out when i looked at it. Weird thing is i don't think the clutch is gone because it slips when its cold, but when i try to burn it just a bit the problem goes away. Either way it still engages really high. Scorke, did you have this with your exedy twin?
I had an Exedy Twin and I could NEVER get hte pedal right and when I finally did it would just move itsself out of adjustment again. The clutch was junk IMO and my ACT held up 5x's better and it wasnt even the HD. I was recently putting in my Motor and realized my Exedy Twin with less than 10k needed to be replaced. Im now going to do a Xtreme Pressure plate, I doubt ill buy another Edexy after all of that money for it to last that long.
I had nothing but problems since day one.
I was shocked at how much of a difference that one turn of that pushrod made with respect to moving the engagement position.
I can probably live without double clutching; the setup is grippy as hell and I'm enjoying the butter-smooth shifts again.
Mellon Racing
176
May 30, 2017 05:45 AM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
vaflyboi757
Dec 18, 2015 10:27 AM
