Going to bleed clutch, which brake fluid did you go with?
I have half a bottle of DOT3 Prestone brake fluid, and I would like to bleed my clutch. Just curious if using this is ok, or whether or not I should just go get something else.
Also, dot3/4, whats your recommendation? Thanks!
You could use the half full bottle for the clutch, but I would get fresh fluid for the brakes. Like we all know, brake fluid absorbs moisture from the air, which is a no no when it comes to hot brakes.
If I were you, I would go to the local parts store and get the cheepest DOT 4 brake fluid.
They share the same fluid bro...
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
jaycee842
11
May 27, 2016 06:35 AM
tdanmorello
Oct 10, 2008 09:01 AM
