AEM Wideband
Old Feb 24, 2008 | 06:00 PM
shanowano's Avatar
AEM Wideband
Hey everyone I am looking to get an AEM Uego wideband o2 sensor and just wondering where would I stick the sesnsor? I know you need to have it 36 inches from the turbo so as not to cause premature wear. So could I just stick it in the test pipe where my rear o2 sensor is located?
Thanks
Old Feb 24, 2008 | 06:03 PM
cush87's Avatar
I have mine mounted on my test pipe, just after the downpipe; reads perfect.
Old Feb 24, 2008 | 06:04 PM
kreionic's Avatar
you could but then you will get a check engine light for not having the rear o2 sensor. You can bypass the check engine light with this thread but you wont pass emission
https://www.evolutionm.net/forums/sh...d.php?t=268138
I have my bung welded for my wideband on my downpipe.
Old Feb 24, 2008 | 06:06 PM
JKTUNING's Avatar
If you need to pass emissions.. I would just weld another o2 bung on the downpipe where ever you have room for it, instead of putting it in your test pipe replacing the secondary o2 sensor.
If you don't have to pass emissions, I would just disable the secondary O2 sensor and do the resistor trick for the secondary heater. Then put your wideband where the secondary sensor would be.
Old Feb 24, 2008 | 06:14 PM
shanowano's Avatar
Thanks for all the quick replies I do not need to pass emissions and so I was thinking of getting a mechanical o2 fix, bascially an extension so the sensor sits farther away from the test pipe. Has anyone had sucess with this?
Old Feb 25, 2008 | 10:10 AM
shanowano's Avatar
Or would everyone recommend adjusting it through evoscan and ecu?
Old Feb 25, 2008 | 12:02 PM
MR Turco's Avatar
This is exactly where i put my sensor. No problems so far.
https://www.evolutionm.net/forums/sh...ad.php?t=84914
Old Feb 25, 2008 | 01:39 PM
chaotichoax's Avatar
I linked this thread to the other mods and it'll likely be stickied in the how tos by the end of today
211Ratsbud
Dec 12, 2013 01:04 PM
Evo1001
Jul 22, 2011 09:25 PM
jrod4484
Jun 2, 2011 08:58 PM
mikiblueeyes
16
Oct 15, 2009 11:18 AM
shunderwunder
Nov 30, 2007 04:11 PM
Quick Reply: AEM Wideband
