Full-Race twinscroll GT35R+Cosworth Heads and Shortblock+Cams.
Old Mar 1, 2008 | 01:47 PM
DarthSuperShado's Avatar
What will be spooltime on a Evo IX MR, with AEM EMS, Meth injection,93 Octane premium, Full cosworth engine package, Full race fuel rail and GT35R Twin scroll kit...
Also my question is. How much whp can i make safely on 93+meth max?
And will it be too laggy? Thanks... I just want to know the RPM the car will rocket like a bat out of hell..
Old Mar 1, 2008 | 01:53 PM
crcain's Avatar
According to my calculations, batt out of hell mode will be reached at 4937.3 RPM.
Old Mar 1, 2008 | 02:23 PM
So im **** outta luck for wanting a 35r to spool around 3k's? Not necessarily full spool... i just dont want my car to bog down on a roll like when i press the pedal down. i dont wanna wait more than 1.5 seconds..
Old Mar 1, 2008 | 02:33 PM
BoOsTinGEVO190's Avatar
how about 2.3 TS hta35r with everything else
Old Mar 1, 2008 | 02:39 PM
ZyBeR's Avatar
Ok setup, but sell the AEM and get a MoTeC M800 OEM, it's a whole other level of ECU.
Old Mar 1, 2008 | 02:43 PM
EvoDan2004's Avatar
<---------- full race ts 35r 1.06 hotside stock ecu 26psi at 4550 rpm. WITH no tuning and compressor surging.
i will not spill out any more info. hehe
Old Mar 1, 2008 | 02:53 PM
turbosmurf02's Avatar
Op, are you running 2.3/4 L stroker??
Old Mar 1, 2008 | 02:55 PM
EvoDan2004's Avatar
oops
2.0l STOCK block.
Old Mar 1, 2008 | 03:01 PM
Gsxtremedsm's Avatar
Sounds very nice evodan... What did you do to fix your surge?(i forget did you try to run the same .78a/r hotside that you had with the 30r? Or was it the lack of an anti-surge cover) Do you think that it would surge again if you were to do the HTA modification to the TS 35r?
Also where did you get the 1.06 a/r? Isn't this still nearly impossible to find?
Old Mar 1, 2008 | 03:05 PM
EvoDan2004's Avatar
i still use the 1.06 hotside. i orderd a anti surge cover. it will be here tuesday. so lets hope for the best.
the 1.06 is hard to get. but since im so cool i got one. haha.
Old Mar 1, 2008 | 03:16 PM
Does the 1.06 T3 hotside fit everything in your full race kit the same? (I assume, just want to double check because I think I am going with a TS 30r, but if I build my engine down the road then I might go with a 35r as long as I can keep the T3, and not have to go to a T4 manifold/everything
Old Mar 1, 2008 | 03:17 PM
EvoDan2004's Avatar
what do you mean? yes it fits. the only change would be the hotside. nothing more.
if i kept my 30r i would of added a 1.06 to it. i used a .78. bro trust me. go 1.06. if u can find one.
Old Mar 1, 2008 | 03:23 PM
What is the difference in spool.. What benifit does the 1.06 have other than some peak power?
Old Mar 1, 2008 | 03:24 PM
From my understanding a 1.06 is like a .83 single scroll which is a little to big for a 3076r.. the .78 is like a .63 which is what most people use. Also where did you get your 1.06? I plan to run E-85 most of the time at around 26-28psi. I want around 450ish whp with good response and torque. Does this change your opion?
Old Mar 1, 2008 | 03:29 PM
EvoDan2004's Avatar
but what u forgot is its twin scroll not single. a 1.06 hotside will still spool mega faster then a single scroll .82 hotside. you cant compare a single scroll to ts spool up. there 2 very different parts
