ETS 61mm kit has arrived + some misc. parts
PS w you will need bigger injectors and a dual pump if you want to push the setup. I have the same thing but I am running 1000cc at 60% duty cycle and buschur in tank pumps with aeromotive regulators. good luck though
I will be running 93 octane until I build the bottom end.
Until then, this fuel set up should be ok.
I know I can't push the turbo very far with current set of injectors.
