ETS 61mm kit has arrived + some misc. parts
Old Mar 12, 2008 | 10:20 AM
  #31
JordanS4's Avatar
Originally Posted by evilbada
We were talking about dynojet.
Oh are you going to go to a dynojet or jsut use CF's?
Old Mar 12, 2008 | 10:24 AM
  #32
DTM's Avatar
DTM
780cc injectors ARE PLENTY. Don't believe everything you here.
Old Mar 12, 2008 | 11:28 AM
  #33
evilbada's Avatar
I was just saying about 450whp on dynojet = 400whp on mustang.
Let me just say I'm shooting for 400whp on mustang dyno.
That works now?
Old Mar 12, 2008 | 11:32 AM
  #34
JordanS4's Avatar
That works now?
I think you took it the wrong way I was just curious if you were going to dyno the setup at both DTM and on a dynojet since our setups are almost identical I was curious to see your results.
Old Mar 12, 2008 | 12:04 PM
  #35
evilbada's Avatar
Yes, I will take it to a dynojet later just to see what the number is.
Old Mar 25, 2008 | 09:53 PM
  #36
brandon1304's Avatar
.... i want results hahaha!!!! im possibly ordering this kit tomorrow!!
Old Mar 25, 2008 | 11:21 PM
  #37
el brusco's Avatar
Results??
Old Mar 25, 2008 | 11:38 PM
  #38
Turbo Kyle's Avatar
Nice lookin stuff
Old Mar 26, 2008 | 08:14 AM
  #39
Boltz.'s Avatar
FCOTM Winner
Why did you not opt for the S cover over the E?
Just curious...
Old Mar 26, 2008 | 09:34 AM
  #40
evilbada's Avatar
Update : Prior to the turbo installation, I had a problem with oil pressure. The cylinder pressure was 120 across the board except 4th being 128.
I thought it was idle related but apparently it was oil pump going bad taking the motor with it.
DTM is building my motor : 2.3L bottom end, built head, and exedy twin HD
Stay tuned for before breakin and after breakin numbers
Old Mar 26, 2008 | 09:35 AM
  #41
evilbada's Avatar
Just curious...
E cover flows plenty enough for my application.
Old Mar 26, 2008 | 09:47 AM
  #42
mdsevo06's Avatar
I don't get how doing a compression test would show the oil pump going bad? And 8 psi difference is exceptable. From one tester to another, there can be differences as much as 10 psi. Just curious.
Old Mar 26, 2008 | 10:06 AM
  #43
evilbada's Avatar
I had oil pressure light come on brieftly when the idle fell below 1000, which is explainable as the car is trying to die.
But I also had the light come on from 2000 to 1000rpm occasionally.
Each time the light came on, my pressure reading would go below 10psi (DEFI BF gauge reading).
The compression test was done afterwards.
~163-170psi across the board is where it should be.
and 120psi is not in the acceptable range.
I didn't want to risk blowing the motor especially when I'm adding a big turbo.
And hell, I was going to build my motor anyway at some point or another.
Old Mar 26, 2008 | 10:09 AM
  #44
SPEED's Avatar
very nice, you wont regret the stroker at all.
Old Mar 26, 2008 | 10:13 AM
  #45
evilbada's Avatar
I didn't think I'd go from an average evo to a 'holy **** built!! evo' in a matter of a month.
But still your car is a monster!
Quick Reply: ETS 61mm kit has arrived + some misc. parts
