Ask AMS and Buschur Part 1: 2.0l or 2.3l?
Also think about what is happening when your 2L is reving at a higher rate than a 2.3, you are staying in a lower gear for longer, which multiplies torque and accelerates the car faster.
i am not an engine builder nor a mechanic...however i am an engineer...
to put it in easy terms..going 2.2 will give you faster spool, and higher rev limit than the 2.3 yet maintain better (closer to 2.0) geometry...and the piston speeds at higher rpm are not rediculous like the 2.3
Keep in mind that it is not piston speed that kills the piston but acceleration at the top and bottom of the stroke... the longer stroke of a 2.3 puts significantly higher forces on the rod when the piston changes directions...
mean piston speed has not changed much since the 50's an old matchless single cyl motorcyle engine had a mean speed of 23m/s.. ducati's newest MOTOGP bike has a mean piston speed of 25.5m/s. Not that much of a difference...
What is different is that acceleration at the top and bottom of the stroke...
AWD Motorsports
37
Aug 8, 2010 12:10 PM
AWD Motorsports
67
Jun 2, 2009 10:22 PM
