why wont it move
why wont it move
i just had some motor work done and ran into a problem like always. i had my mechanic install some cams for me hks 272 to be specific. now for some reason when he goes to do his crank checks it will rotate one time and then get stuck. he pulled off the cam and said the dial pin was pushed into the cam due to missalignment. he is saying that the intake cam is not rotating. is that even true? can the dowl pin stop the cam from moving. what else can it be. put stock cams back in for the time being and worked fine. please help out
i had the same thing happen to me when i did my cams ... i ended up changing my cam gear bc the pin missed the hole and putting a dent inside the cam gear. The camshaft pin also slide into the camshaft it self.... i was able to drill and pull it out tho. the cam will rotate free of the gear some bc there is no oil pressure to hold the cam gear in place. But mine did not get stuck that says a cam is 180 out or something
