New Launching Aide Innovation
Old Mar 13, 2008 | 06:47 AM
  #31
MR Turco's Avatar
So it is line lock with a restrictor valve when the line lock lets off? Not a bad idea.
Old Mar 13, 2008 | 06:59 AM
  #32
Shearer's Avatar
Originally Posted by gsnt
Keep in mind that this piece is specificly prohibited by the NHRA/NDRA rulebook if you have intentions of running it in that series. I'm not sure about BOTI or any other sanctioning bodies thoughh, it may fly there.
Similar devices have been being used in Hot Rod and Pro Front for quite a long time already.
Old Mar 13, 2008 | 07:16 AM
  #33
Ivan@AMS's Avatar
Originally Posted by DynoFlash
Switch the switch and you have a controlled perfect launch every time
Why would it need to be adjustable if you get a perfect launch every time?
Old Mar 13, 2008 | 07:21 AM
  #34
kmcconn9's Avatar
To adjust for the vast array of clutches available out on the market today....
  #35
juanmedina's Avatar
will this work on subies
Old Mar 13, 2008 | 07:28 AM
  #36
9sec9's Avatar
I think it's a great idea. It sounds exactly like my tractors 3 point/brush hog. Speed up or slow down the drop/lift. Good idea that moves us forward technically.
Old Mar 13, 2008 | 07:43 AM
  #37
U2SLO's Avatar
Yes it will work on subies , on that as we speak, yes subies are next in order. STI's-WRX's
Old Mar 13, 2008 | 07:52 AM
  #38
fusionchicken's Avatar
GREAT news main reason i got the 2.5rs/STi hybrid is the weight factor...a 29xx lbs car launching with consistency every time...damn this is exciting
subscribed!
Old Mar 13, 2008 | 08:39 AM
  #39
jmartinez1170's Avatar
I knew it was some kind of line lock. As i said in the other thread.
Old Mar 13, 2008 | 08:53 AM
  #40
kouzman's Avatar
that's a pretty cool feature for drag racing! Can't wait to see the results...
Correct me if I am wrong... Its like an adjustable pill like the oem unit in the clutch line, right?
Old Mar 13, 2008 | 09:00 AM
  #41
DynoFlash's Avatar
Originally Posted by shunderwunder
Will these come pre set to an average clutch release speed for launching so that we have an idea where to start dialing it in from. Just a thought that may help a little & save some clutch durring initial setup. Is there any idea of price & a time frame when it will be released?
The easy way to set it is start really slow and then start turning the knob a bit at a time till the car starts to take off well
Better to start easy than hard
  #42
lexat20's Avatar
Now if you could just make a contraption that will shift 1-2 2-3 and 3-4 perfect everytime.
Old Mar 13, 2008 | 09:24 AM
  #43
DynoFlash's Avatar
Originally Posted by hotrod2448
How does it only regulate your launch in first and then let the clutch work normally through the other gears?
I'm guessing it has a bypass and 1st gear switch but, it's hard to tell from the pic.
Two options
1. AEM equipped vechicle - it works by configuring a switched output based on vechicle Speed and engine rpms it would autoamtically turn on.
2. Factory ecu equipped vehicle it is activated by the button - you hold down the button when you want it to work
NOTE * There is discussion of a third option which would include a line lock type clutch release where you get both the controlled clutch engagement AND a activation that is triggred by releasing a button like a line lock
Al
Old Mar 13, 2008 | 09:25 AM
  #44
DynoFlash's Avatar
Its called the Evo X with the auto trans
This aide is just for launching the car to get a good laucnh without breaking parts and take out the trial and error and learning curve also removing the possibility of human error
Old Mar 13, 2008 | 09:27 AM
  #45
DynoFlash's Avatar
It is very similar to the fluid control concept of the oem clutch restrictor
Differences are that its only active on the launch so it does not effect the other shifts
Also - its fully adjustable to allow the end user the ability to dial it in perfectly for his / her car
