Okada Project Plasma Blast Ignition Coils
Has anybody ever tried these? It sounds promising, but I don't really see people buying it. What are the pros and cons about these?
I haven't really seen much difference with them. The tendancy to knock doesn't seem to change and whether you are able to run 1-2 degree more timing is arguable based on conditions that do not revolve around the ignition coils. Have I had spark blow out with the stock units or okadas nope. They may however offer something at high power levels (500whp+), but at 400+ dollars i do not see the justification.
IMHO you are better off putting the money towards something that will yield "proven" power.
Plus I don't think you will see a huge difference on a stock car may be more resistant to spark blow out but I think the factory ones work well enough for what I am doing and would like to see some more testing with them. Dsport used them on their triple threat evo in the January issue here is the article
http://www.dragsport.com/issue/2008/..._article.shtml
Hope this helps
Hope this helps
still have my 01 vw turbo running APR software on a slightly larger turbo, bosch coilpacks are said to be weak, when i scan with Ross-Tech it always shows missfires, pretty expensive trial, i replaced stock coil pacs already with supposed upgraded ones. most vw owners complain of this issue
