Evo top mount manifold
#40
If u test fit it and it fits without interfering with anything and if your not going to use it. Im very interested in buying it.
Very nice work man. Wish I had the tools and materials so i could be doing the same thing.
Have you measured the runners at all to see if there close to be equal length at all ? Maybe you can make a TS t3 one then ill really be bugging you.
#43
To doing this yourself. These projects are very rewarding. One constructive tip I would give you. Its not the best for flow, making the oval transition from the head port to the round port of the runners, to all be done in the head flange. Its a good idea from a manufacturing standpoint until one looks at what airflow likes and doesn't like.
Cheers
Cheers
#44
well the manifold has been done. i've been busy making other stuff. here are some pics. im not going to use it anymore because im going with a bottom mount now. it works with the stock radiator also.
