which meth kit to get to hit my 500hp goal
Old Jul 1, 2008 | 01:27 PM
  #31
KidEvo's Avatar
Let us know how it turns out. Recently a few people at TTP having been hitting 430whp with the stock turbo on a Mustang Dyno using a TTP Meth kit.
Old Jul 1, 2008 | 10:28 PM
  #32
staatz's Avatar
I have teh SMC and it supports 600hp..I remember seeing your vid and maybe its just the turbo?
Old Jul 1, 2008 | 10:35 PM
  #33
TTP Engineering's Avatar
You cannot rate a meth kit or jetting size by a horsepower number. It depends on a number of factors including compressor, boost, efficiency of the turbo, VE of the motor and on and on.
A small stock turbo at 35psi needs more cooling and flow than a larger turbo in most cases as the larger turbo is more efficient at providing the same amount of boost at a COOLER temperature.
Old Jul 1, 2008 | 10:37 PM
  #34
4WS Tuning's Avatar
I'll make a pitch too!
Labonte ftw!!! Over 600whp with the kit...
You can run multiple large nozzles to provide the proper pressure thanks to the big pump, numerical flow gauge, fail safe, anti-drip or anti-siphon solenoid, low level indicator... etc etc etc
Shoot me a pm if you'd like more info.
Cheers!
Old Jul 1, 2008 | 10:46 PM
  #35
You have to be careful with methanol kits and invest in a company that will give you sound advice.
You never know when you might run across a company that would install an M12 and an M8 methanol nozzle on a stock turbo Evo and hydrolock the engine, in turn crushing the rod bearings and inducing rod knock.
Be careful who to trust with your $35,000 investment, because in the end the customer is left responsible for any engine damage that can occur from poor advice or installation of improper jetting.
Old Jul 1, 2008 | 10:47 PM
  #36
DynoFlash's Avatar
This is great news to hear - however - IMHO it totally misses the point
ANY alcohol injection kit out there can aide you to make a LOT more power than you can without alcohol. How much additional power you can make is dependant upon how much alcohol you inject and how agressive your tune is.
Comparing one kit against another based upon how much power one tuner made on a particular car is a POOR way to comapre alcohol systems.
The wise customer should examine the features and functions of each kit and make a decision based upon which kit has the best combination of features to suit his intended use.
One point I would make on the subject is that I would NOT recomend ANY system which does not have a fail safe function. The consequences of a alcohol system failure are simply too costly to run a system that does not have a active fail safe protection.
Al
Old Jul 1, 2008 | 10:51 PM
  #37
Al
We concur. Very responsible post Alfried.
Old Jul 1, 2008 | 11:32 PM
  #38
4G63 T's Avatar
Al
Few years back you advocate using SMC kit, are you/will you still recommend this brand?
Old Jul 2, 2008 | 06:04 AM
  #39
deadbeatrec's Avatar
my aquamist didnt come with a failsafe other than the gage. i was kinda disaponted when they said it had one.
Old Jul 13, 2008 | 05:26 PM
  #40
bank277's Avatar
No one has mentioned coolingmist. Are these kits ok?
snafufx
31
Apr 11, 2009 09:02 AM
spooch
Apr 12, 2008 08:46 PM
spooch
ExtremeTurboSystems.com – WA
Mar 24, 2008 10:12 AM
turbodreamz21
Feb 10, 2008 03:45 PM
Pure Playaer
13
Dec 26, 2007 07:47 PM
Quick Reply: which meth kit to get to hit my 500hp goal
