View Poll Results: What size injectors do you use on a HTA3076?
Voters: 38. You may not vote on this poll
HTA 3076 turbo owners What injectors are you using?
What boost and what fuel? If you're looking for "just big enough" you might be somewhere between the 780 and 1000, but if you're gonna do E-85 you'll need the bigger of the two at least
Even if you're going to use just pump gas I'd still get the 1000's like evodan said... why buy injectors twice?
750/780 will be plenty. With a Green at full tilt (one pump, gas, 30+psi) I am seeing 65-70% IDC on pump at 28-29psi and 75% or thereabouts on racegas at higher boost. Thats a turbo that runs 49 lbs/min or so. The HTA uses a 57# wheel for comparison. Adding the meth will richen your AFR's almost a full point in most cases so it will make up what is lacking.
