stiff shifter base bushings for MR 6 speed
#32
Ok got the Buschur underhood shifter bushings installed.
Had about 3 hours of driving time today. Definitely noticed it wasn't as spongy while shifting between gears, but when the shifter actually goes into gear it still has play in it.
Like the shifter can still move forward if pressed on while in gear. I'm guessing base bushings from WORKS will fix this? Just ordered them. I just want to have a shifter thats tight with little to no play.
I'm following this up with a short throw.
#33
i had my clutch installed and put the Buschur UH bushings in and now its hard to shift in to reverse, i can put it in reverse if i do it fast. impossible to get in if i do it slow. would adjusting the clutch help? oh yeah and i can feel the different, going in to gear is more accurate and precise.
#34
I'm curious about this issue too. Sometimes I can get into reverse fairly effortlessly, other times it's damn near impossible. I haven't noticed if I was shifting faster or slower though. It seems that it's an issue with Buschur's bushings since I haven't heard about it with anyone elses, although I can't imagine anyone's being much different.
I doubt it's a clutch issue if it was fine prior to the bushing swap. Maybe a shifter cable adjustment, if such provisions exist.
Kracka
83
Jan 20, 2017 12:54 PM
Grey Razor
17
Nov 18, 2006 05:22 PM
