stiff shifter base bushings for MR 6 speed
First off I want to say that I already searched and couldnt find anything really useful enough for me to trust.
Do they make any shifter base bushings for the 6 speed? I've seen them for the 5 speeds and really like how they feel. I want the same rifle bolt feel for my 6 speed.
From what I've heard the 8 peice base bushings fit but I went to lancer shop they said 5 speed only.
-thanks
-thanks
Call Nate at SpeedSource.net They sell both the MR base bushings and the underhood ones for very good prices. I have bot of these on my 05 MR 6 spd
The base ones are made from aluminum. Easy install about 1 hour.
The shifter cable bushings under the hood are brass and it takes about 45 minutes. It is easier if you remove the battery box but not required.
Shifter feel is much improved.
Milburn
Milburn
Milburn
Milburn
Also does your shifter now feel like a rifle bolt when you put it in to gear and is there any play or is the shifter really stiff now?
-thanks man!
when i had the cable shifter bushings in it really didnt make that much of a difference, but my car was really hard to get into reverse and 1st gear sometimes. once i switched back, it was normal
Yeah thats why I don't want them just the shifter base bushings. I heard the under hood cable bushings are really only for cars that are older and need replacing.
