Q Horsepower Synthetic Oil....
Old Apr 2, 2008, 12:33 PM
  #31
OneFast4Door's Avatar
Just curious, what wrong with Royal Purple??
Old Apr 2, 2008, 12:58 PM
  #32
hopper's Avatar
its purple for one
I have seen many issues with RP from oil breakdown. Personally Id rather have my oil company market an oil not a color
Old Apr 2, 2008, 01:21 PM
  #33
Oil Doc's Avatar
Originally Posted by evolved83
Thegame, its called mitsu getting paid to put mobil 1's label on the oil cap. They do this so that they can make people such as yourself think that exact statement you just made to be true.
EXACTLY !!!!!!!!!!!
They don't Research anything... they create a Spec..... The Spec isn't Mobil 1 .... The Spec is Viscosity, Grade and Synthetic...
Now, to Royal Purple...... Royal Purple shears out of Grade Extremely fast just for starters.. Great, it made 7 HP over, I believe, a Petroleum oil. For how long ? AMSOIL was tested in a Corvette, which comes with Mobil 1 from the factory, by Vinci Performance for Corvette Fever Magazine... From memory, there was a 6 HP gain with using the AMSOIL over another Premium Synthetic.
The only tests I have available anymore are Royal Purple Motorcycle oil and RP Gear Lube.... Both of which failed miserably in Independent Tests... Which, I thinks states what the rest of the companies products are like...
I will go back to this... Forget MSDS, Forget Oil Analysis, I would like to see ASTM Tests along with Technical Data Sheets... If a company is hesitant about making them public, what is that really saying about their product ?
Doc
Old Apr 2, 2008, 01:24 PM
  #34
krazy srt4's Avatar
because of quaker state oil my engine is now blown so i love it!!!!!
Old Apr 2, 2008, 01:52 PM
  #35
Oil Doc's Avatar
Although Quaker State is not my favorite oil by a long shot, I would place money on it that it did not cause your engine to blow, as long as it was the proper weight, grade and it was synthetic as Mits recommends for the EVO.
Doc
Old Apr 2, 2008, 06:47 PM
  #36
krazy srt4's Avatar
i used 10w30 synth.... i have never had a problem as i always use mobil 1 i decided to use quaker form some stupid reason and 2 days later i spin a bearing and from what everyone tells me quaker is cheap recycled oil and not good
Old Apr 2, 2008, 07:04 PM
  #37
wizzo 8's Avatar
AMSOIL pm me with prices on engine,trans, diff and transfer case oils
Old Apr 2, 2008, 07:18 PM
  #38
Oil Doc's Avatar
Coincedence ? Maybe....
Anything is possible, that is why it is ALWAYS Wise to pull an oil sample for analysis AND pull the oil filter and place it in a plastic bag to avoid contamination..
I have seen OEM's back down from blaming an oil when tha analysis comes back good.. and I know of at least 1 Filter company that has bought more than one engine.
Doc
Old Apr 2, 2008, 07:20 PM
  #39
Oil Doc's Avatar
Will have you covered in the AM.... I am not on my office computer..
Thanks, Doc
Old Apr 2, 2008, 11:29 PM
  #40
SYNRGY's Avatar
i want to change out all my fluids since im at 20k miles, drop me a pm Oil Doc.
Old Apr 3, 2008, 12:58 AM
  #41
Oil Doc's Avatar
Will do.... It will be sometime today (Thur)... It is 4am and haven't been able to sleep... Hence, answering what I can on home computer.
Doc
Old Apr 3, 2008, 05:40 AM
  #42
Davo's Avatar
this is just some btw info
i sold my b14 sentra with a sr20de jdm high port and it used quaker state all the time and dino oil mostly with some syn blended in between
had a jwt ecu which was not sold with the car and many other parts that were scrapped too
new owner put mobil full syn in, same weight as i was using and lately he developed a timing chain noise
i gave that engine more abuse with the ecu(higher rev limit than a stock ecu) when i had it and he has a unmodded engine and did some damage
i like my quaker state but for the evo is amsoil front to back
Old Apr 3, 2008, 06:25 AM
  #43
SYNRGY's Avatar
damn, have about two cases of q hp oil. seems like its a mix of 50/50 on like or dislike. I'm a mobile 1 synthetic guy but seems like amsoil is a superior oil compared to it.
Old Apr 3, 2008, 06:27 AM
  #44
SYNRGY's Avatar
Doc
same here. 2am and go to work at 7. guess I'm used to it. all I can say is damn do I knock out once I'm asleep. in case you need zip its 78216. thanks doc
Lancer905
Toronto Lancer Club
Nov 29, 2010 02:47 AM
imamamasboy
Toronto Lancer Club
Mar 31, 2009 06:25 PM
TexasRalliart
Oct 10, 2006 03:16 AM
BlueEvo04
May 21, 2005 11:08 AM
Boost Solutions
84
Aug 1, 2003 07:11 PM
Quick Reply: Q Horsepower Synthetic Oil....
